‎2025-02-06 07:25 AM
Hello I have downloaded education version 28 on imac but NO license key is shown on the installer or after it has installed
The license key is not shown on the Graphisoft downloads page in my login where all previous education versions are shown with their expired codes so cant reuse any of those Any help here ??
Operating system used: Mac Intel-based Ventura 13.4.1 (c)
Solved! Go to Solution.
‎2025-02-06 07:58 AM
Did you follow these steps?
https://community.graphisoft.com/t5/Licensing/Educational-License-Step-by-step/ta-p/343590
If you still have trouble, follow the contact information at the bottom of the page.
‎2025-02-11 04:51 PM
The final step is to activate your Archicad educational is with the serial number.
- Open Archicad,
- a window above will appear. Select the Trial/Educational Serial number, and then press Continue.
- Now complete the fields with your information: User ID (your email registered in Graphisoft ID) and the serial number ( in myarchicad account page)
as @Barry Kelly reported to you, read this article:
Giovanni Logiudice
Educational Community Expert, Moderator
Certified GRAPHISOFT ARCHICAD BIM Manager‎2025-02-20 07:39 AM - edited ‎2025-02-20 07:40 AM
You can check your email or Graphisoft account; support can resend the key!
