Installation & update
Need help deciphering error message
Hi all,
New archicad 11 user here, doing my best to make the switch from autocad.
I have a model that was created in revit, saved with ifc2x4, saved again as a pln. The doors and windows were ifc, which I changed to archicad doors and windows from the archicad stadard library. All was going well, until I tried to get a 3d view, and I got this message:
"Fill not found at line 105 in the 3D script file wa_trim_us_10.gsm"
I get this for all doors and windows. Any ideas what the fix is?
Thank you,
Kristen
Hi Kristen,
Try doing a search for "Fill not found at line 105". It has been discussed a few times over the last few years.
Here's one to start you off!
http://archicad-talk.graphisoft.com/viewtopic.php?p=122755&highlight=fill+line+105#122755
Another possible solution -
http://archicad-talk.graphisoft.com/viewtopic.php?p=73914&highlight=fill+line+105#73914
Hope that helps!
Have you checked 2D and 3D representation parameters in the window library part?
Replace all "missing fills" by new ones of your choice...
