Luke3
New ArchiCAD 29 Serial Number doesn't work.
New Serial Number that just sent me says it is invalid on ArchiCAD 29.
Operating system used: Windows 29.3000
2 Solutions
Can you start Archicad and run in demo mode with no license?
If not you should be able to get the update from the Graphisoft website.
As far as I know there is no difference between EDU and commercial versions except for the actual license.
https://www.graphisoft.com/en-au/downloads/?section=update&localization=AUS&product=archicad&type=FU...
Go to post
Gorazd
Yes, it should work. New serials requires latest ac29 update
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
Go to post
5 Replies 5
You should probably edit your post and blur the serial number.
I know you were trying to show us it is the same.
Have you upgraded your Archicad as was suggested?
Luke3
Says I have to open my ArchiCAD project first and then return to the page.
Luke3
Thanks I'll see if that update works.
Gorazd
Gorazd Rajh
