15 hours ago - last edited 15 hours ago
New Serial Number that just sent me says it is invalid on ArchiCAD 29.
Operating system used: Windows 29.3000
15 hours ago
You should probably edit your post and blur the serial number.
I know you were trying to show us it is the same.
Have you upgraded your Archicad as was suggested?
15 hours ago
Says I have to open my ArchiCAD project first and then return to the page.
14 hours ago - last edited 14 hours ago
Can you start Archicad and run in demo mode with no license?
If not you should be able to get the update from the Graphisoft website.
As far as I know there is no difference between EDU and commercial versions except for the actual license.
14 hours ago
Thanks I'll see if that update works.
10 hours ago
Yes, it should work. New serials requires latest ac29 update
