Nothing works anymore
Hi
I cant open archicad anymore. it crashes when i open any file, new old it dont make no difference.
this started happening after i installed the latest nvidia drivers today.
all my restore point on xp are clogged up with amyuni pdf installs ( which really pi**es me off)
anybody know what would help.
I might just reinstall archicad....
Any help is appreciated
5 REPLIES 5
I think i figured out what caused it.
NVIDIA Desktop Manager
This is important:
1. All the nvidia drivers are (geforce) are useless.
2. They are not compatible with Archicad when used with Dual TFT screen set up.
3. Do not use the Nview Desktop Manager, it will cause unexpected results when working with Archicad and crashes.
4. I have updated my Nvidia drivers 3 times now since Sept 2004 and everytime one problem dissapears and another appears.
Good look to the rest of you with the same set up.
Aussie John
glad you got it working again
Cheers John
[/size]
Does anybody know of a fix to the Amyuni PDF thing installing everytime you start Archicad? I have the full Adobe suite, so would i be able to uninstall Amyuni and just use Acrobat 6?
All of my restore points are clogged up with Amyuni.....
Anyone got a solution?
patricprz wrote:
Does anybody know of a fix to the Amyuni PDF thing installing everytime you start Archicad?...
maybe this will help:
http://www.graphisoft.com/support/archicad/archiguide/SaveAsPDF.html
You are the DAUG!
Thanks
