I have now completed some tests and it appears that OSX can not print line thicknesses correctly (G5 OSX 10.3.9 ArchiCAD/Plotmaker 9 - printing, not plotting).
Set up a test page with 100% black lines on a red background (colour not important):
0.13mm wide lines at 0.26mm C/C as stripes, and also as a grid of squares.
0.25mm wide lines at 0.5mm C/C as stripes, and also as a grid of squares.
0.35mm wide lines at 0.7mm C/C as stripes, and also as a grid of squares.
0.5mm wide lines at 1.0mm C/C as stripes, and also as a grid of squares.
This should give a series of lines with gaps equal to the width of the lines.
Print (not Plot) and the scan the results at, say, 1200DPI.
Counting the pixels gives the line/gap widths, which in any case should be equal. Counting the pixels will give a true line width, in this case 25.4mm/1200DPI should give the pixel size in mm.
However, non of the large format printers I have tested print the line thicknesses correctly. All make the lines thicker, the best 50%, the worst 100%. In the worst case the stripes disappear into a black mass!
Please can other Mac users test their large format printers as above and report here. Am I alone in wanting my 0.13mm lines to be 0.13mm, and not 0.25mm?
Regards,
Nick Harvey
