Thank you for the move Thomas.
Yes -- I did consider the G5 tower options as well as I've always been a bit leery of purchasing an "all-in-one" computer with the screen and motherboard combined. As others have noted, the lifespan of a good monitor can certainly exceed the CPU in this industry and keeping these components unbundled is probably a wise decision.
However, the costs do mount as you note. Here in Canada, the 20-inch screen from Apple is about $1799 (yes, you can get cheaper from others but where is the fun in that?)
When you consider that the same 20-inch screen combined with the 1.8 GHz G5 iMac innards costs $2499, you can see that you've managed to get everything else for approximately $700 (relatively cheap in the Apple universe; no comment about Wintel).
I'm currently on a 600MHz G3 so the speed improvement should be dramatic. While we have ArchiCAD 8.1 (and it is a massive improvement speed-wise over AC 8 on the Macintosh), our older hardware and large number of projects started prior to AC 8 keep us on ArchiCAD 7 most of the time.
There have been some preliminary benchmarks posted for the new G5 iMac as follows:
Cinebench results:
CINEBENCH 2003 v1
Processor : iMac G5
MHz : 1.8 GHZ
Number of CPUs : 1
Operating System : 10.3.5
Graphics Card : 5200
Resolution : 1440x900 (17-inch screen)
Colour Depth : millions
Rendering (Single CPU): 243 CB-CPU
Rendering (Multiple CPU): --- CB-CPU
Shading (CINEMA 4D) : 228 CB-GFX
Shading (OpenGL Software Lighting) : 558 CB-GFX
Shading (OpenGL Hardware Lighting) : 695 CB-GFX
OpenGL Speedup: 3.05
and an Xbench score of 134.71
* at first glance the 243 score is not that impressive as other Cinebench rendering results for Macintosh computers are:
DP G5 2.5ghz: 649
DP G5 2.0ghz: 522
DP G4 1.42ghz: 247
PB G4 1.5ghz: 135
For those on Windows OS, these machines post the following:
DP Xeon 3.06ghz: 655
DP Opteron 2.0ghz: 523
DP G5 1.8ghz: 471
SP P4 3.2ghz: 384
SP G5 1.8ghz: 251
SP G5 1.6ghz: 222
So faster than a 1.6GHz G5, practically a dead heat to the original single processor 1.8 G5 GHz tower. One big thing to remember, however, was that the initial benchmark was done on a "stock" iMac G5 without any RAM upgrade. Apple continues their strange policy of shipping machines with less than optimal RAM (the base should be 512MB minimum at this time!)
I'm getting mine with the stock RAM and upgrading via 3rd party RAM. Note that if install same capacity RAM DIMMs in both of the slots, they wil operate on a 128-bus. If a single DIMM or different capacity DIMMs are installed, each will work via a separate 64-bit bus (this from the Developer Notes available as a PDF download from the Apple site).
I will provide my first-hand impressions once the machine arrives and been set-up (complete with the RAM upgrade).
> Thomas also wrote:
> And I've used Mac since 1985. But I can't afford a BMW, I'm driving a SAAB.
Got you beat... used/owned Mac since 1984; first tried ArchiCAD in 1989 (owned since 1991), and I'm driving a 1964 Plymouth Valiant with push-button gear selector for the transmission.
Senior Associate, Chernoff Thompson Architects
ArchiCAD 16 (firm uses Revit)
Mac OS X 10.10 on Mac Pro (2013)
3.5 GHz 6-core Intel Xeon w/64 GB RAM & Dual AMD FirePro D700 w/6 GB Graphics
1 TB SSD w/20 TB RAID 1
Asus PB287Q 4k UHD 28-inch monitor (3840x2160)
