Open file dialog is blank white!
when i choose to open new file.
i cannot see my files.
only blank screen
7 Replies 7
Is this ARCHICAD 22? What is the language of your Windows? Is it Windows 10 or some other?
its the trail version.
windows 10 hebrew
I will inform GRAPHISOFT HQ about this issue.
I can confirm that after changing windows display language to English the issue has resolved.
Thank you for addressing this issue the graphisoft.
its important for compatibility with the Israeli users
I am glad you managed to handle the issue for now.
Still, GRAPHISOFT developers are looking into the issue to resolve it.
Daniel Kovacs
We managed to find what causes this in ARCHICAD 22. Apparently on Windows with a language version that writes from right to left, the "Open/Save dialogs" appear blank. We are planning to include a fix for this issue in the first update (build 40xx).
Until then you can go on using ARCHICAD 22 on these systems if you only open projects by double-clicking on them from the file browser or drag-and-drop them on the ARCHICAD window.
If you want to create a new project or save as, duplicate the projects in the file browser as well. The save command still works as that requires no dialog.
You can also switch the OS language to English until the fix arrives.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
is this solved in 1.3 version?
