2019-06-12 01:21 PM
Solved! Go to Solution.
2019-06-18 04:11 PM
2023-05-01 10:53 AM - edited 2023-05-01 11:04 AM
Hey, it really was a scaling problem. i was using a custom size in windows. reverted to a preset one and now it work.
In the option of monitor size i was using 110% zoom, reverted into 100% and now it looks normal again, thx for anonymous post above.
2019-06-18 01:27 PM
2019-06-18 04:11 PM
2019-06-19 03:14 AM
2019-06-19 10:33 AM
2023-04-07 10:22 AM
Hello, i have the same problem with pen settings. In the pen set options it looks normal but once I go to view map it change pen set to diagonal format. Can you explain more about the solution you wrote? Because i did not understand what you actually did to solve this. Thank you much.
2023-04-08 10:57 AM
They look like 2 completely different pen sets.
make sure you are not using a 'Custom' pen set.
2023-04-09 09:06 AM
Hey, every pen set is doing the same thing, custom or the saved one it doesnt matter. I tried uninstall and install archicad but nothing changed. Every pen set is displayed like this, in diagonal order.
2023-04-11 04:02 AM
Hmm, it seems you pens set has only 12 rows when you choose to select a pen.
There should be 13 as in your pen setting dialogue.
I would be contacting your local Archicad support people.
I have never seen this before.
