Rick Thompson
Panther G5 specific issues
I understand a few previous post were deleted...dj this is a repeat in essence.
This seems to be serious. I have installed Panther on 2 computers, a DualG5 and an 800TiBook. I have 8.1 build 1290, which is not actually the last one, however I would be surprised if a later build is going to make a difference. I can not plot on the G5 from plotmaker. Plotmaker crashes almost every time, but if I plot 1 sheet, sometimes it works. I have cleaned the preferences but the problem persist. I can plot as usual on the Tibook, so to plot is requiring a move of the lbk and pmks, so I can't link. I plot stock plans daily...this is awful.
If anyone has a dual G5 and can plot from plotmaker (more than one sheet, a set of several sheets), please let me know...thank you
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
10 Replies 10
I can.
Are you plotting to a plotter or a spool folder?
I typically plot to spool folder, and use Plotflow. hehe. still in classic! Let's go Graphisoft.
Rick Thompson
Todd wrote:
I can.
What AC version are you on, that might be a notable difference. I do use plotflow...but not in classic, however it behavies the same via file or straight to plotter.
Rick Thompson
Mac Sonoma AC 26
Plotflow is non-classic now? sheesh. Where did you get your fingers on that?
I'm using Panther, and ArchiCad v. 8.0.0 v3 build 6318 on a dual 2 GHz G5. Plotmaker v. 3.0 build 6318.
Hmmm... maybe 8.1 is not an upgrade. What is new with 8.1?
Rick Thompson
I'm stumped...you can plot, I can't. I reinstalled build 6318 and again trashed all preferences, and it will crash when I try to send to a spool folder, same as before. I can plot a sheet (sometimes) without crashing, but not a set to a spool folder.
Rick Thompson
Mac Sonoma AC 26
Djordje
http://www.graphisoft.com/products/archicad/upgrade81/
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Have you tried plotting from ArchiCAD?
Not that you would want to for output, just as a test.
Rick Thompson
yes, but only 1 sheet at a time, which I can do most of the time in PM. It seems to plot 1 sheet ok, but not always. I just printed 7 sheets, one at a time, then tried again and it crashed...frustrating
but thanks
Rick Thompson
Mac Sonoma AC 26
Rick Thompson
It was a corrupt font! I got a response from support who was stumped too. They then asked the responsible developer who suggested a bad ram module or corrupt font. I trashed the font and all was well. I had dragged installed from another computer and it became corrupt.
Rick Thompson
Mac Sonoma AC 26
maybe you need suitcase to scan your fonts and delete the one corrupt..
sometimes in osx there are some font files who are activated by apps...then you can't see it,
if you use something like suitcase, you can correct your font problem....
hopes it will help you
R
