Installation & update
Pen Number Error Message
After framing a wall using CadImage I switch to a 3D window and an error message appears stating that " Pen number is greater than 255 or less than 1 at line 27 in the 3D script of file Wall Frame 3D.gsm" When I check properties of the wall frame sure enough the background fill pen assignment is -1....any ideas on why and hoe to correct it without changing each wall individually?
Select them all (filter with "find and select") and change just that setting. No other settings should change.
Thank you Stuart that was very easy..still can't figure out why it selects -1 as a pen color but I have a call into CadImage and anticipate an answer reall soon.
