gpowless
Performance Issues [AC 23]
I have found a number of performance issues with AC23 that wern't there in the RC version.
1. Adjusting heights or widths of complex profiles is incredibly slow. Selecting a node to stretch cause a spinning ball for 10-15 seconds each time. If I over shoot the mark I am attempting to adjust to the spinning ball reappears and takes another 10-15 seconds to respond.
2. Most profile offset modifiers can't be adjusted in 3D. Occassionaly they will adjust by small increments but most times selecting the adjustment bar does nothing.
3. When the trace reference is turned on in plan view and I switch to 3D view orbiting is slow for a short (20-30 seconds) period. Once it has (I assume) updated or completed the operation delaying the movement it appears to operate as normal.
I will keep adding to this thread as I find anything else....
Intel [email protected] 16g
10 Replies 10
cbplay
Thank you! We were getting horrible latency between every click.  After days of trouble shooting AC 25 on a well running iMac/ big sur with 5k retina, this is what fixed it. We tested hardware, wiped the machine and put it back on Catalina, tweeked every work environment setting, AC tech support with logging, chased missing library objects.  All we had to do was drag it over to a lame second display and it worked flawlessly.  It appears AC just cant handle a 5k monitor....
