Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Installation & update
Hello everyone, I have a big problem on Windows 7 64bit and ArchiCAD 15, the problem is that the menu REPRESENTATIONS Creative> Create a Fly Through, is no longer possible to use "Document QuickTime movie" does not see but you can click.
On the same machine is installed the version of Archicad 14 and above option works properly on other machines I have the version of ArchiCAD 15 running on XP 32-bit and everything works properly. To resolve this problem, I already trail most roads, including those reported in the same Graphisoft that still does not declare this alleged BUGS, although at the following link reports of malfunctions due to QuickTime
In addition to making the solutions in the previous LINK I also:
- Uninstalled and installed the one from DVD QuickTime Archicad 15
- Uninstalled and reinstalled Archicad 15
- Updated to latest version of QuickTime and even Archicad 15
All this has not led to any results, if anyone can help me I would be grateful.
Best Regards
Marco Pardi.
