Project data & BIM
Plotmaker 3.1
After importing all DWGS into plotmaker, arranging on each sheet etc. I need to add one more room ele to the project.
Can't seem to find option anywhere, only import [filename].pln, which I assume I will need to rearrange everything again??
Is there an option to add?
Thanx
_____________________________________________
ArchiCAD 8.1 R2 AUS/Win XP Pro/Pentium 4/3.2gig/512 ram
Aussie John
hi Aussie Jane,
Import is the way but it wont effect your previously added files.
Just select the appropriate quickview from the list that appears after selecting the Archicad file
Cheers John
[/size]
Djordje
Right click on the layout you want to import the elevation in, choose Import, choose the PLN file, choose the appropriate view in it, and check Place on current layout - or create a new one, as the case may be. You can add and delete as much as needed.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanx to you both.
It worked well!
