Print PDF size 0
Have been having issue printing to pdf for awhile. Many times published pdf size is 0. I think it has something to do with having an image view in the layout. Very frustrating. I can reset or rename publisher set and it fixes sometimes. I can delete and reinsert the image to layout and it fixes sometimes. Tired of work around. Have 3 windows/pc workstations in office and all have same issue. What is the fix?
1 Reply 1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you very much for the report and I am very sorry for the experience!
We have some reports similar to this one. What usually happened is that the PDF cannot be saved properly if the path is too long.
The easiest workaround is to publishing the PDFs to a location with shorter path, for example straight to the C:\ drive.
Please let me know if it answers your question!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
