Installation & update
Quick TIme error
All,
After installation of Archicad 13 and then starting the program I am getting this (see attached)
Please help...
I did install the quicktime and new java applications from the CD, but I am out of luck on this one...
Thank you
DDJUSA
11 REPLIES 11
Ingolf
Two steps to avoid this Problem:
1. Turn off your PC/Mac and start once more.
2. If this doesn't help, uninstall QuickTime and install it once more from the internet. http://www.apple.com/quicktime/download/
Good Luck
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
Ingolf,
I also have that issue and tried your suggestion, but that didn't work?
Any other suggestions?
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Browse the install DVD and there is a folder on it called "SUPPORT" Try to run "GSQtComInstaller.exe" in it. Does that help?
Gergely Kmethy
All,
I got an answer from Graphisoft about the error.
Step 1. GO TO C:PROGRAM FILES\COMMON FILES FOLDER
Step 2. Look for a folder name "Grpahisoft Shared"
Step 3. Delete this folder
Step 4. Browse the AC13 CD and go to the folder D:/SUPPORT and Install the file GSQtComInstaller.exe
Step 5. Restart Archicad.
It worked like a charm.
Thank you
DDJUSA
DDJUSA Wrote...
"I got an answer from Graphisoft about the error.
It worked like a charm. "
This didn't work for me!?
Shaun C
If ArchiCAD still won't run after installing "GSQtComInstaller.exe", you should next run the vcredist installers in the "SUPPORT" folder ("vcredist_x86.exe", "vcredist_x64.exe").
Shaun Coomber
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
this still didnt work?
Shaun Coomber Wrote:
"If ArchiCAD still won't run after installing "GSQtComInstaller.exe", you should next run the vcredist installers in the "SUPPORT" folder ("vcredist_x86.exe", "vcredist_x64.exe")."
I tried this too, and it didnt work
compu
I had the same problem on AC13 installation.
Upgrading QuickTime to 7.6.4 and Graphisoft's answer (deleting "Graphisoft Shared" folder) solved the problem.
Regards.
archisem.com
