Installation & update
Reference Line Flip Button
Takis
While drawing a wall, if the mouse passes over the reference line, the Reference Line Flip Button becomes disabled.
Please see attached files.
Archicad 21, Build 6000.
Takis
I have moved this topic as it is not really a general discussion about Archicad.
Just to clarify you post a bit I think you meant to say...
While drawing a wall, if the mouse passes over the guide line creation button, the Reference Line Flip Button becomes disabled.
It does this in version 20 as well so it is not just a problem with the latest preview update.
Takis
Barry, you are absolutely right, thanks.
Takis
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello guys,
Wow, I totally thought that was just happening randomly, thanks!
Until it is fixed you can actually use the P key to flip the wall when this option is greyed out in the Info Box.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
