Installation & update
!Restored: 6.5 in 10.3
anyone get 6.5 to run in classic mode in osX.3 yet?
I only need to do it so i can move all the 6.5 details into 8.1 on my laptop while traveling !
I can't get the key installer to work like it used to, and new version of the driver doesn't seem to do it either. is it not possible anymore?
I suppose I can just open the 6.5 projects in 8.1 and convert them that way, but it would still be nice to get 6.5 to work..
thanks!
Katie Bertsche
various Mac G4s and a new 1.25 mhz powerbook, OSX.3
14 REPLIES 14
so far had no success, even starting up in OS 9, because AC 6.5 cannot detect the dongle.
JCovarrubias
Graphisoft Alumni
Graphisoft Alumni
Please see
GSKB 388 "WIBU driver for AC 8 in OS X, and 6.5 in Classic mode"
at
http://tr.graphisoftus.com/
in the FAQ's (Knowledge Base)
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
henrypootel
If you have your System restore disks(or a system restore disk from an older mac), you can grab a System 9 folder from there.
Josh Osborne - Central Innovation
HP Zbook Studio G4 - Windows 10 Pro, Intel i7 7820HQ, 32Gb RAM, Quadro M1200
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
You don't have to boot in 9 to be able to run ArchiCAD 6.5. It's enough to run the classic shell. However, you have to modify WIBU setup to be able to use the WIBU key. See Archiguide article at:
http://www.graphisoft.com/support/archicad/archiguide/wibuinclassic.html
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
Finally AC 6.5 in OS X. would have been better were it not for installing and uninstalling, and, restarting throughout.
