2004-05-12
05:35 PM
2025-01-30
12:41 PM
Molinda Prey
2004-05-14 09:37 AM
2004-05-22 02:12 AM
2004-05-25 01:39 AM
Steve wrote:Just as a side-note, I believe AC 8.1 can open earlier files as old as ArchiCAD 4.5. So you don't have to worry about that.
That's what I do Katie, just open them in 8.1 and keep on going! We were told that 8.1 wouldn't open previous versions, but seems to open 6.5 projects perfectly, then once saved they are now 8.1.
2004-06-21 02:56 PM
2004-06-21 05:21 PM
2004-06-21 05:23 PM
JCovarrubias wrote:in your ./Applications/Utilities folder you should have a 'Software Restore' application. run this (even on newer macs without 'classic' preinstalled) and it will give you the option to install OS9 classic on your machine . . .
without the OS 9 system folder (which is not found on newer Mac's), ArchiCAd 6.5 will not run (or even install on OS X for that matter)
2004-06-21 05:26 PM
~/archiben wrote:would this procedure give classic emulation, or restore the actual OS 9 "System Folder" ?JCovarrubias wrote:in your ./Applications/Utilities folder you should have a 'Software Restore' application. run this (even on newer macs without 'classic' preinstalled) and it will give you the option to install OS9 classic on your machine . . .
HTH
~/archiben
2004-06-21 05:34 PM
JCovarrubias wrote:ah! i see the problem. it installs a system folder for classic emulation unfortunately - not an OS9 startup system. . . but this could be something to do with OS9 disk drivers.
I am able to run classic emulation, but AC 6.5 will NOT even install because of amissingOS 9 "System Folder"
2004-06-21 07:10 PM
~/archiben wrote:i'll keep this tip in mind when I (or any of the end-users I work with) format a Mac hard disk, thank you.
when you reformat a hard drive (from the install disk> "Erase Volume" or similar) in OSX now you have the option of installing 'OS9 drivers'. maybe if this option is taken, the disk can be used as an OS9 startup . . . ? not 100% since i haven't used 9 for a long while now . . .
sorry for the earlier misunderstanding. let me know how you get on . . .
~/archiben
