Streamline your workflows and master BIM coordination! Program starts April 28.!
Installation & update
!Restored: Network keyplug and one computer
Hi all
I was trying to install ArchiCAD 8.1 on my home computer, but I have my companies network keyplug. I have installed network driver, but key is not recognized. I was told, that in order to work with net keyplug, I must have network connection to at least one additional computers. Is that true? Does anybody run this configuration at home?
henrypootel
Partially true. You don't need either to get the net key to work, but you do need an IP address. you can use "localhost" or "127.0.0.1", but i'm not sure if this will work if you don't have an IP address. I will check this later and post back here.
Josh Osborne - Central Innovation
HP Zbook Studio G4 - Windows 10 Pro, Intel i7 7820HQ, 32Gb RAM, Quadro M1200
Gorazd
This configuration is to be set as henrypootel said. You just have to install network licencing utilities from WIBU (you get that with network keyplug). In Control Panel/wibu key Network tab you enter folowing "server ip" 127.0.0.1.
It works for me.
Gorazd Rajh
From AC 6.5 onward, Ryzen 9 5900HS, 48 GB RAM, RTX 3080, Win 11
Thank you both. It works now.
