Installation & update
!Restored: Problem in ArchiCAD 10-need help as soon as posible
I installed Archicad10, but it is not working right. I can not see library parts in window, Tool box is empty...
Does someone know what is the problem?
19 REPLIES 19
WhiteMan wrote:
What is SP2???
SP2 are some kinds of updates for windows, is that right?
But that file is over 250mb!
ah service pack 2.
That means you are running on a very ancient version of XP, I think.
have you tried my method?
Should be less painfull than installing window packs
I did not understand you. Where to find AC.lfc file, I am not shore about that, maybe I will lose the whole library?
File>Library and Objects>Library manager
you Remove the lfc file from the right collumn (Active Libraries) and add the archicad library folder from the left column.
Djordje
If you have slow dialup connection, check the computer magazines; they usually enclose the CDs with Service Packs for Windows.
Proveri sa PC Pressom, oni sigurno imaju CD.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I installed SP2, but it is still not working
Any other idea?
Djordje
Any other idea?
Pffff ...
Did you also run all the updates from Microsoft Update?
Updated video card drivers?
Djordje
HP Omen
I'm not sure if when you update it actually repairs your windows.
That is what worked for me
I already had full SP2 installed.
As I already said....and I had the same issue
REPAIR windows and give it a try
Don't you just love Windows?!
http://archicad-talk.graphisoft.com/viewtopic.php?t=10525&highlight=
You will most likely need to insert your XP install disk and select REPAIR from the install options.
Here is a good tutorial on doing that.
http://www.informationweek.com/showArticle.jhtml;jsessionid=STKGFAI0KVUKAQSNDLPSKH0CJUNN2JVN?article...
You need service pack 2. If you don't have it you should get it.
