Installation & update
!Restored: TIFF problems
I'm having trouble inserting TIFF images in ArchiCAD. Jpeg works fine, as does some tiffs I've received from others. I've tried saving the tiffs with just about every option I can come up with (MAC/PC, uncompressed, no layers, nocolour profile etc.) and tried both Merge into ArchiCAD and using Figure settings. When using merge I get the confusing message that it couldn't open the Pict image.
I'm using AC7 on a mac.
Oh, and is there an EPS importer to be found anywhere?
/Sanna
make sure the image is in RGB format? I've had trouble with CMYK images not importing...
hth
Wes
Try converting (in Photoshop) tiff image to 8bits colour mode. The same is for jpeg images. Maybe it works.
