Matthew wrote:
While I hope that XP is better...
Indeed it is!
Tim,
I hope you haven't already done a clean OS install.
The Repair function of XP does indeed work well ... as does System Restore. Don't resort to a reformat and clean install until you've exhausted those options! If you do, you'll lose ALL of your settings and also have to reinstall all software...
Have you tried Safe Mode yet? If not, reboot your computer, and start tapping the F8 key after the initial BIOS screen and you'll get a boot menu with Safe Mode as one option. Try doing a Restore from there. In fact, you might even try uninstalling AC9 from there first. Hard to believe AC9 caused this, but you never know.
If that fails, insert your original XP install disk and boot from it. (You may have to change BIOS settings or press a key on reboot to boot from CD.)
If your computer was already upgraded to XP SP2 and you do not have an SP2 installation disk (almost nobody does), you may need to create a 'slipstream' cd by following the instructions at this link:
http://www.winsupersite.com/showcase/windowsxp_sp2_slipstream.asp
I created one last night in less than 30 minutes.
Proceed in the XP menus as if you are going to install. You will come to a point where it notes that you appear to have an XP installation on such and such a partition. It will offer you the option to repair it ("R" key)... If you do that (last resort before reformatting here), it will attempt to update all system files that don't match the installation media. Prior to SP2, I have had success with this on two client computers ... all user settings remained intact and life was normal again. I assume that with a slipstreamed SP2 CD, that the same would be true now if your computer has already been upgraded to SP2.
If this all sounds intimidating, find a local computer guy who understands what I just wrote.
Good luck!
PS The behavior that you describe seems consistent from my experience with a failing hard disk. Installing AC9 should not cause this kind of behavior. When you have things recovered, or even beforehand in Safe Mode, you should do a complete surface check of your system volume - probably c: (right mouse C: from My Computer/Explorer, Tools tab, click "Check now..." then check "Automatically fix file system errors" AND check "Scan for and attempt recovery of bad sectors".
AC 28 USA and earlier • macOS Sequoia 15.3, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
