2020-10-09 10:56 AM
2022-12-15 08:28 AM
I am not sure about that ECODesigner star error.
In 25 and before I can understand it is there if you do not have and ED* license.
But in 26 it it supposed to be built in now as far as I know.
But I just started 26 and I get the same ED* license activation failed message.
I don't use it anyway so I just ignore it.
2023-03-29 12:50 AM - edited 2023-03-29 12:51 AM
When I open ArchiCAD 26 i also get this error message pop up:
2023-03-29 03:10 AM
I just opened 26 and did not get this message.
So at some point since I last posted, it has fixed itself - I never noticed.
I just checked in the HELP menu and it shows I have a license.
But you do need an SSA/Forward support agreement.
If you have a support agreement then contact your local support to ask what s happening.
Without a support agreement, you will not have EcoDesigner STAR - yous standard EcoDesigner.
05:26 PM
2025-08-29
04:03 PM
I am also getting this error although the Ecodesigner is activated in the license tab with the SSA.
C:\Program Files\Graphisoft\Archicad 26\Archicad.exe
Unused in temporary folder : 1658040.0 MB
EcoDesigner STAR license activation failed.
Protection Error Code: 200
EcoDesigner STAR Add-On functions will be disabled.
You can continue using Archicad without the features of EcoDesigner STAR.
Conversion of Objects to MEP elements begin.
Statistics:
Checked elements: 16.
Objects without MEP elements removed: 0/0.
MEP compatible elements converted: 0/0.
Inconsistent elements: 0/0.
Derived data updated: 0/0.
MEP structure created: 0/0.
Segments with unconnected holes: 0/0.
Repair function #1: 0.
Converted to Objects: 0/0
Conversion of Objects to MEP elements end.
Projection : Front view
Camera azimuth : 270
Start time : 5/10/2023 6:20:35 μμ
End time : 5/10/2023 6:20:35 μμ
Elapsed time : 0 seconds
Is this the reason that all me files even a new wmpty one when I select repair the give an error that are fixed but some objects might be deleted???
I never get a health file after repair even a new one!!!!!!
This happening with 26.
Thanks!
2025-08-29 03:45 PM
Any solution for this in 2025?
Using AC28 and still getting an error message in the session protocol even though the licence is active. I would like to have a session protocol without an error message.
2025-11-14 05:14 AM
Wonder if the issue is some sort of delay in the licence authentication.
