Installation & update
Script to deploy Archicad 17 on Mac with ARD
Hello everybody,
Perhaps someone is interested by a script to deploy Archicad and his patches on many mac workstations with Apple Remote Desktop.
You must be root to run it.
You can find here my script :
First, you must have a sharepoint to copy your Archicad package (made with the installation program) and all the patches (if not cumulative).
My sharepoint is "ACHotFix" hosted on a mac server.
# Create a mount point on the workstation
mkdir /Volumes/Install
# Create a temporary directory Temp on first level
mkdir /Temp
# Mount the sharepoint hosted by a mac server
mount_smbfs //login:password@name_of_server/ACHotFix /Volumes/Install/
# Copy all files necessary to install in the Temp directory on first level
cp -r /Volumes/Install/AC17-FRA-3002.app /Temp/
cp -r /Volumes/Install/AC17-4005-HOTFIX2-MAC.app /Temp/
cp -r /Volumes/Install/AC17-4008-HOTFIX3-MAC.app /Temp/
# Install Archicad 17 and the patches
sudo /Temp/AC17-FRA-3002.app/Contents/ArchiCAD\ Installer.app/Contents/MacOS/ArchiCAD\ Installer -silent
sudo /Temp/AC17-4005-HOTFIX2-MAC.app/Contents/MacOS/AC17-4005-HOTFIX2-MAC -silent
sudo /Temp/AC17-4008-HOTFIX3-MAC.app/Contents/MacOS/AC17-4008-HOTFIX3-MAC -silent
# Delete all temporary files
rm -r /Temp
# unmount the mount point
umount /Volumes/Install
Have fun
Kind regards
Hi Patrick,
Thanks for that. These are really useful since Graphisoft's own OS X ARD deployment document seems to be totally out of date.
I've made my own, which I think is a bit easier to use since you can just feed it a URL to the hot fix image:
https://gist.github.com/filipp/8975071
These are beautiful. Thank you both!
