Liamthanks
Shadows in 3D View (V23)
Hi all,
When using V23 on my work PC, whenever shadows are turned on in the 3D view settings, I get a white model effect. The other 2 PC's in the office do not have this issue and I did not have the issue when using V20.
I've tried looking through the settings that I am aware of but can't work it out. Do you guys have any suggestions as to what is causing this?
Thank you.
AC27 Build 5060 AUS - Windows 10 Pro, Ryzen 7 5800X, RTX 3090, M.2 NVME 0.5TB SSD, 32GB RAM
1 Reply 1
Check in each file the Quick Options Palette if 3d Styles are exactly the same.
Hope that helps.
