Simply question about DUCTWORK,Thanks.
Coule somebody tech me how to connect a higher pipe & a lower pipe by using DUCTWORK?
thanks a lot~~~~~~~~~~~~~~~~~`
3 Replies 3
I suppose you want to autoconnect 2 horizontal pipes on different elevation.
Unfortunately autoconnect feature won't work here. You have to do it manually, step by step, like on attached screenshoot. You can change elevation, but not direction and elevation at the same time.
I hope it helped.
What is this DUCTWORK? An Add-on or what. Could you give me some idea?
Thanks,
Joseph
Thanks,
Joseph
This is ArchiCAD Add-on for HVAC services 2D/3D design. Can't perform any specialist calculation but can build 3D model and most of necessary HVAC services 2D documentation. Take a look at
http://www.graphisoft.com/products/productivity_tools/ductwork.html
