We value your input!
Installation & update
Skylites Not Cutting it
Whenever I use the Skylite tool, whether in v8 or v8.1, with different roof thicknesses and/or angles, I see the bottom of the frame of the skylite underneath the roof, but it doesn't cut thru the roof, as advertised..
Naftali
5 REPLIES 5
skylight is not dependent to roof angle or thickness. even after you place a skylight and change the thickness of the roof ,the skylight will cut it automatically. may be you have two roofs in one level?
Djordje
Have to check it, but there is a minimal slope below which the skylites do not cut. What is your roof slope?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
One is 20% and the other is 32%
Naftali
You actually measure your roofs by percent of slope?
Ooops
Make that 20 and 32 degrees
(one of those days)
Naftali
