Installation & update
Solo Project: Object unable to edit?
Very strange issue where one user is able to edit objects (ie - delete) while another user cannot. The file is not opened simultaneously, both users are using the same version of AC. Noticed that the object is locked for one user, but not the other, even without changing anything in the file.
If this has occurred for anyone, would like to hear solutions to correct this, as it is very cumbersome to workflow.
1 REPLY 1
David Maudlin
Test123:
This could be due to the use of MEP objects, see this post (near the end): BATHROOM FIXTURES MISSING IN AC 12 US LIBRARY?.
And check your signature, you are about 8 versions ahead.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
