[Solved] Missing features in ArchiCAD SE mentioned in docs
Sam Karli
This is a funny issue, but, while reading the manual, I realized that some stuff mentioned in "What's new in Archicad 2010 SE" chapter of the (Hungarian) help is simply missing.
The doc mentions an upgraded Automatic Dimensioning (Automatikus méretezés) under the Documentation (Dokumentáció) menu, but (at least in My copy) there is no Documentation menu at all. I haven't find it anywhere.
Any idea.
GDL/Python/C++ dev
NCornia
Sam,
Perhaps you have your profile set to "Visualization". With this profile the Document menu does not appear. Try choosing Standard Profile when starting a new project or in an existing or open project go to Options>Work Environment and change your profile.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Sam Karli
Wow,
Indeed, I used a Visualization profile, and applying a Standard solved the problem
Thanks
GDL/Python/C++ dev
