Karol Argasinski
Startup Window in ArchiCAD 22
Dear all,
Accidentaly I clicked to "do not show window at startup". Is there any possibility to get window back?
Cheers!
OPENBIM does works!
ArchiCAD 22/23/24/25/26/27/28/29 INT &POL
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M3 Max 16C/40G, 128GB, 2TB
http://www.bimfaktoria.pl/
1 Reply 1
David Maudlin
Karol Argasinski:
There is a command Enable All Informational Messages... which should restore that (and other) dialog boxes. You may need to add it to your Work Environment.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
