Installation & update
Temp files not deleting
Upgraded to Tiger, but server is running OSX Server 10.2.8. AC9 is now saying "Unable to delete temp file XXXXXXX" Try again? If you try again, it sometimes deletes, sometimes doesn't.
Quitting out of AC and trying to delete in finder doesn't work--says File is in use by AC
Is this happening to anybody else?
Ideas?
__archiben
the temp files are on the server? sounds more like a permissions issue than anything else. try searching the forum - several similar queries have been raised about this . . .
good luck
~/archiben
b e n _ f r o s t
Am having exactly the same problem same server version and client versions - have you had any luck?
Thanks
Kevin
