Using Archicad 16 with license for 17 - keep losing 3D model
Hello, I am currently using AC 16 with the AC17 license so that my files are compatible with coworkers who are on 16.
I'll be working along back and forth between 2D and 3D, and then suddenly will "lose" the model. 2D drawings are still there and showing on sheets, but 3D is completely gone.
OS is Windows 7.
Thanks
1 Reply 1
If you select a few elements in 2D and display only selected elements in 3D, does it show?
Or, if you switch to axonomeric view, do they show?
Is it possible that in the Filter Elements in 3D dialog the included Story setting or the Marquee setting causes it?
