PYA
Very Frustrating AC27 keep crashing
I am very very very frustrating with AC27,  My AC27 keep crashing almost every time when I try to edit the text.  It crashed when I use delete key to remove unwanted text. It is very very very bad. Can't get work done. I have to retype text in order to get work.
Spoke with local sales team in USA. no help. they did not aware this.
I also updated AC27, but still no luck.
PS. I have reinstall AC27 many times.
Operating system used: Mac Apple Silicon 27,  use MacBook Pro m3 max 2TB, 128 ram
Archicad 25-27
MacBook Pro M1 Max 64GB Sonoma 14
4 Replies 4
Eduardo Rolon
There is a CAPS lock issue were if you tyoe with it on it crashes on certain files.
See here: https://community.graphisoft.com/t5/Installation-update/macOS-Sonoma-Caps-Lock-Issue/m-p/585134#M365...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
PYA
Thanks, I will pay attention see if it is related to CAPS lock.
Archicad 25-27
@PYA  Are you running that most recent hotfix update released last week... The About screen should show Build 4060...
PYA
Yes I updated with hotfix updated.
Archicad 25-27
