Marc H
View Tab Right Click Not Showing 'Stories' ("Profile Editor TabBar Menu")?
Running AC24 and when I right-click the tab to quickly go to another story, I'm met with an unfinished label. Seems a little clean-up is in order.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
6 Replies 6
Minh Nguyen
Hi Marc,
Thank you for sharing this issue!
Unfortunately, I cannot reproduce this on AC24 INT on Windows or AC24 GER on macOS. I'm wondering which language version are you using? Does this happen even with a brand new file, after spamming some dozens of stories into it?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Marc H
Hi Minh,
Thank you for your prompt response. I am using the USA version on Catalina. I did not add any stories to the model. However, it is a large, older project with hotlinks, generated back in 2016 (AC20?) and migrated since then. Given its age, I opened a few other projects created in prior AC versions. I found the 'TabBar' display appears to occur in projects created prior to AC23. (The two projects I created in AC23 and one I created this morning in AC24 display the correct menu choices.)
Minh Nguyen
Hi Marc,
Thank you for your report! I will try to replicate this issue with older Archicad versions and see if I can make it appear in the context menu!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Minh Nguyen
Hi Marc,
I created a simple file in AC20 with 30+ stories. Upon opening the file in AC24 INT on Windows and AC24 GER on macOS, I still see the correct "Stories" label in the context menu. Unfortunately, I was not able to instal AC24 USA on macOS for testing.
I'm wondering if you could give a try with this file and let me know the result?
Thank you very much!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Marc H
Hi Minh,
Yes, it came up with the TabBar label.
Minh Nguyen
Hi Marc,
It turned out that the issue happens with Archicad 24 USA version, but not on other versions. I have entered it as a defect in our database. I hope that it will be fixed soon!
Thank you once again for your finding! Have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
