2005-10-11 05:46 PM
2005-10-12 05:29 AM
Srinivas wrote:Windows:
Can I find the WIBU - KEY - Serial Number which I used to save a file?
2005-10-13 07:08 AM
2005-10-13 04:44 PM
Srinivas wrote:Not if it is not plugged in the machine. The files are lock independent.
Thanks for the reply, but right know i don't have the lock with me which i used to save the files. I just had the Archicad files with me.
Can i still find the lock serial number?
2005-10-18 10:40 AM
2005-10-18 04:27 PM
"Srinivas" wrote:
One way of finding the wibu-key serial is through the log file of Archicad which it registers when archicad stops responding or when it crashes.
The filename will be "ArchiCAD.RPT" and it will be in your C:\Documents and Settings\username\Graphisoft folder (on PC).
Here in this file you can view the wibu key details and you can trace the wibu-key serial number.
I know this and wanted to share this information with you. That's it./quote]
GoodForgot about this one.
