WIBU - thick, gooey, molasses!
Not sure if this is a "hardware" topic or a "new user" topic - forgive me if Im in the wrong forum!
Since moving to my new computer (G5 imac) I am vexed by the "Protection Key is Not Responding" dialog... every time a dialog is opened, or an action performed I see the dialog flash as the system "looks" for the key.
Sometimes the dialog will stick for up to a ten-count before disappearing.
Any ideas or suggestions?
3 Replies 3
Does it work fine in other computers? This would indicate a USB problem. Have you tried different ports? It is usually best to plug the key into the computer itself. Un-powered hubs (like the keyboard) don't always work well (though I have had no problem with this lately).
It is also possible that there is a problem with the key itself. This would be indicated if you have similar problems on other machines.
lohden -
thanks - it seems to be a problem limited to one machine only and a restart seems to solve the problem - at least temporarily. so until and if the problem returns we're happy campers for now.
Djordje
leporello wrote:
lohden -
Did you check the same key on other machines? If it does not happen, then it is the machine - if it does, it is the key. Better replace it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
