Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Installation & update
Walls and stairs
I am a new user to archicad.
Could someone please tell me how to add walls to the underside of staircases.
I want the wall to cut off at the steps and only enclose underneath the stair.
Rocket10
Hi there, welcome to the forum. You may find the information you require in one of these threads....
http://archicad-talk.graphisoft.com/viewtopic.php?t=5861
http://archicad-talk.graphisoft.com/viewtopic.php?t=6174
You can use the search function (top of all forum pages) to help locate info using key words (that's how I found these).
Another tip often given to new members is to add system info in a signature so others can give answers relevant to your setup.
Hope this helps. Have fun...
Thanks Stuart.
This worked great.
