Installation & update
Where to find Archicad's Serial Number and renew license - (soy nueva en Archicad)
FernandaGG99
Hola, Buenas tardes, tengo un problema con el numero de serie con el que ingreso a Archicad 25, pues no lo tengo ya que hace un año instale el 24 pero no lo volví a usar, por lo que no recuerdo el numero y quiero renovar mi licencia. ¿Donde puedo saber mi numero de serie?
Please use English because this is an English-language forum, hardly anyone here speaks Spanish.
Translation by Google Translate:
Hello, Good afternoon, I have a problem with the serial number with which I enter Archicad 25
because I do not have it since a year ago I installed 24 but I did not use it again,
so I do not remember the number and I want to renew my license. Where can I find
my serial number?
Eduardo Rolon
I presume this is for an EDU account so you should go to myarchicad.com and login there and you will be able to get your license number.
Normalmente las licencias que tienen número son las de estudiantes por lo que ir a myarchicad.com puedes encontrar el número.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
kisa miracle
i applied for one education year but since two mouths when i applied till now i havent received an email  for license renewal
