2004-04-20 05:45 PM
2004-04-27 05:57 PM
L. wrote:I have been curious about ArchiCAD performance comparisons between G5 and P4 Xeon machines. I am a bit dismayed to hear that your experience is that the Pentium is still faster. Have you done controlled testing? Could you post the files (or images of them) used and the results?
I tested both by using the same model, and same rendering method.
The p4 out perform the g5. it wasn't to my expectation that the p4 performed better.
2004-04-27 07:02 PM
2004-04-27 08:08 PM
L. wrote:3.06 is almost twice 1.8, so 20-30% is not so bad ...
well, first of all, i m not using Xeon,
i m using an one year old processor, p4 3.06, it is not a dismay to you, to me too.
as what i told everyone, i m not a pc user, but, the machine that i used really out performed a dual 1.8 g5.
2004-04-28 07:19 AM
Matthew wrote:I am sorry for given out a slight wrong information, according to my IT technician, the water cooled P4 3.06 was hyper threading enabled, and Overclocked to 3.6 Ghz, using very high speed ram modules.L. wrote:I have been curious about ArchiCAD performance comparisons between G5 and P4 Xeon machines. I am a bit dismayed to hear that your experience is that the Pentium is still faster. Have you done controlled testing? Could you post the files (or images of them) used and the results?
This adds to my concern that Graphisoft is neglecting their Mac users. Clearly, based on processor or system performance, there is no reason that the Pentium should be able to outperform the G5.
In ArchiCAD, the graphics card also does make difference.
Money/speed ratio is definitely on the PC side, even with high end brand machines that are anything but cheap.
2004-04-28 08:14 AM
L. wrote:Thanks for the correction/clarification. It seems more consistent with my own experience. The fact that the Mac is dual processor makes little difference since AC doesn't make use of the second one. So it seems reasonable that a souped up P4 could outrun it. The graphics cards shouldn't be much of a difference between the machines since the tests you describe are almost all processor work; the graphics card mostly affects OpenGL.
That is one of the reason why it is so fast.
2004-05-07 05:58 PM
Matthew wrote:hello LS Chew:L. wrote:I have been curious about ArchiCAD performance comparisons between G5 and P4 Xeon machines. I am a bit dismayed to hear that your experience is that the Pentium is still faster. Have you done controlled testing? Could you post the files (or images of them) used and the results?
2004-05-08 01:49 PM
2004-05-08 01:56 PM
Matthew wrote:L. wrote:Thanks for the correction/clarification. It seems more consistent with my own experience. The fact that the Mac is dual processor makes little difference since AC doesn't make use of the second one. So it seems reasonable that a souped up P4 could outrun it. The graphics cards shouldn't be much of a difference between the machines since the tests you describe are almost all processor work; the graphics card mostly affects OpenGL.
I do wonder if there is something wrong with the Mac. You say it froze in the middle of a rendering? I have never (that I can recall) had ArchiCAD freeze during rendering, and I have run some very large files with all the settings maxed out.
You may have some bad RAM. I had some serious performance problems with a brand new Dual G4 1.42GHz machine w/2GB RAM because the vendor had installed some no-name flaky DIMMs. Once I replaced them with new memory from Crucial, I had no further problems.
2004-05-10 09:11 AM
2004-05-10 01:10 PM
James wrote:Five crashes is not normal. I would be surprised if we have five crashes in a month through the whole office. It's probably a lot less than that - I can't remember the last time I had a serious crash - in fact, we may not have had a single crash since upgrading to Panther a few months ago.
My computer at work has just been upgrade from a dual 867 to a dual 1.8 G5.
I'm noticing things to be alot faster, however in my first day with ArchiCAD I had 5 crashes, and not just your normal crashes but computer freezing and an error log being displayed on screen. Seems to only ever happen when ArchiCAD is being used.
Has any one with a G5 experienced anything like this? As I'm not sure if it's the computer or purely coincidental that ArchiCAD is running when it does crash.
