Installation & update
Wide monitor dislike
I have monitor 22" and everything is wide.I don't like it, especially archicad.My circle is ellipse and quadrate is rectangle.So is there any clue for solving this little visual problem?
Hi Davor,
It sounds like the screen resolution is not set correctly. Right-click on the desktop, select 'properties', go to the settings tab and adjust the resolution with the slider. You may find that 1680x1050 or 1920x1080 is the optimum, but it depends on the monitor.
Hope that helps.
Definitely a resolution issue....
I don't believe this: I see now that my question was too stupid I didn't even try to change resolution.I thought it can't be set better than it is.All that because till now I had 4:3 monitor and this new one is 16:9 so I couldn't customize. I set resolution on 1680x1050 and everything is perfect. Peter thank you a lot
