Installation & update
Will ArchiCAD 22 run in macOS Ventura?
Duane Meyers
I'm currently running macOS Monterey and need to upgrade to macOS Ventura. I run AC 26 for all my new projects, but still have several AC 22 projects that I have to get into from time to time. When I have tried upgrading them to AC 26 they run slow. The only issue I currently have with AC 22 in Monterey is that it crashes open closing (aggravating)... will AC 22 do the same in Ventura?
1 REPLY 1
MF BIM
Hello @Duane Meyers ,
I run Ventura 13.3.1 and my AC 21 still runs ok. If you have to upgrade, you could create a time machine backup before so you can revert back to it if things don't go well.
https://mfbim.fr | https://youtube.com/@mfbim | My GDL course on Udemy, try it !
AC24 FRA 7600 - AC26 FRA 4027 | MacBook M1 Pro
