Installation & update
Window Markers in Door and Window Builder
When labelling windows using "Builder Dimensions" in D&WB, 20mm is added to the width and height of the window.
Anybody know why?
Dave
4 REPLIES 4
Dave;
I don't have D&WB but 20mm to each of the width and height sounds very suspiciously like a 'structural oversize' dimension ...
Available (deep & buried) in (most) windows & doors parameters. It sounds like your 'defaults' might have been changed at some stage?
- Stuart
Dave Jochum
Anybody know why?
Dave
I don't have AC running at the moment, but you are getting a rough opening dimension based upon your entered dimension that is being applied to the actual leaf size. Can't remember how D&WB handles this, as it's been awile since I've used it. Look for a parameter setting along these lines.
HTH
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
Unable to find any reference to oversize dims etc
Dave
Found it burried in the GDL. I used to be a technician - now I feel more like a programmer
Dave
