Installation & update
Installing or updating your app. Hardware/software requirements, OS specs.
Work Environment and rendering Bug???
kevin b
So has anyone else experienced this? Sometimes after rendering an image, after I close the rendering window, my work environmet is all screwed up, specifically the Info box has taken on new dimensions. I have to go into WE Dialog and re-apply my scheme. It doesn't happen all the time but often enough when doing test renderings etc that it a huge pain. Haven't been able to see any pattern or predictability to it, maybe there is but I don't see it. Anyone else seen it, know a fix, know if GS knows????
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
3 REPLIES 3
same problem here - info box seems to be the only thing affected, so I just stretch it back to shape.
annoying, and GS should fix it if they can...
David Maudlin
Ditto.
I cannot reproduce the problem, in my case the toolbox gets reshaped occasionally after rendering, working on library parts, or moving between the 2D and 3D Windows. I have added "Palette Layout" to my custom toolbar so I can easily reset the Work Environment after this occurs. Just a Mac issue?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
kevin b
I have the same thing for my palette layout, its just buried another level on the MAC menubar. Still an annoying thing to have to keep resetting. Plus I always wind up ging back to the WE because I worry something else has been changed on me without noticing.
kevin s burns, AIA
massachusetts, usa
Windows 10
