archicad 9
i am pulling whats lewft of my hair out need help please. i previously purchased Archicad 9 back in the day, i really like and do not want to spend a pile of money on something i already bought. i have a key fob 8-5639948
how do i get this to work on Windows 10 ? can someone please help, pretty please with beer on top.
I don't think you will have much luck getting version 9 to run.
The only things you can try are …
1). install the version of QuickTime that is on the installation disc.
2). set compatibility mode for Window 7.
See a similar post here that was for version 13 - https://archicad-talk.graphisoft.com/viewtopic.php?f=5&t=67755#p309238
Guru
Maybe see if you can run Winows XP on a VM, then run AC9 from that?
