‎2009-01-24
09:22 AM
‎2024-04-26
11:22 AM
Aruzhan Ilaikova
Solved! Go to Solution.
‎2024-02-05 04:06 AM
Very sorry about this - we had inadvertently uploaded only the PNG files instead of the actual ICNS
files, thus the replacement would not have worked.
Please note we have now uploaded the correct ICNS files (same link) please try again.
PS > We could not help to also redesign them... 😃
https://macinteract.com/archicad-27-replacement-icons/
‎2024-10-07 09:37 AM
For those who have difficulty distinguishing the original launch icons, we’ve introduced new alternative icons that prominently display the version number for easier identification. You can find all the details about the icon changes in this Knowledge Base article:
Please read it carefully, as the previous solution some of you used is incorrect and may cause Archicad to mistakenly be flagged as a pirated version. To avoid issues, kindly follow the guide in the article.
Thank you!
‎2024-11-08 01:26 AM
Thanks for finally providing an offical solution.
For all long-term followers of this thread (since 2009), please note we will no longer produce Archicad version icons as this solves the problem.
However, if you prefer to produce your own graphic / icon, please refer to the following instructions:
https://smart.macinteract.com/icon-creation-tutorial-for-macos-apps/
‎2024-11-08 01:47 AM
Thank you @Eszter Fulop
Now, if those alternative icons can be saved in the 'Archicad Starter.exe' file (and Mac equivalent) for each new version, then that would be perfect.
We won't have to find and download the new icon as it will already be delivered with Archicad installation.
Thank you.
‎2024-11-08 08:48 AM
Just FYI, when updating Archicad you have to replace the icon again and recreate any shortcuts/aliases you have of it.
‎2025-11-19 12:47 PM
Hi Eszter,
Are the icons being updated to include one for Archicad 29 too?
‎2025-11-19 02:06 PM
The link from Esther only has AC26, 27,28 icons. I made my own for AC29, you can use it if you want. Same procedure as outlined by Esther.
Sorry, Mac only 😞
