beach ball delay when adding or deleting layers
I have many layers for a complex project.
Lately, whenever adding or deleting layers, I receive a very long beach ball pause, before the change takes effect: 15 to 30 minutes, and more.
Thanks for your help.
Archicad 21
MacOS Mojave 10.14.6
64 gb ram
1 Reply 1
Minh Nguyen
Thank you for the question and I am very sorry about the issue!
From my experience, the slowness does not come from the number of layers, but the content inside the layers and how they intersect with each other. Make sure to assign correct Layer Intersection Group for elements that should not intersect with each other. You can also use the Attribute Manager to purge any unused layers.
If this does not help, I would like to have the file for further investigation. Please let me know if it's possible and whether you need a secure place to upload the file also!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
