Got a minute? We appreciate your feedback:
Graphisoft Learn survey
bug report AC25-2021-12-23-15-12-14-5570
mehmetlashari
I'm using Macbook Pro M1 MAX 2021, with macOS Monterey Version 12.0.1
my Archicad is version 25
I get this bug report every time I try to close the app from the top menu "Quit Archicad" if I'm trying to restart my laptop for example. Any idea how to fix that? its bothering me.
Thanks.
5 REPLIES 5
PBalazs
Hello there,
I have the same problem with a Macbook Pro M1 Pro, macOS 12.1 with Archicad 24.
I'm hoping for a hot fix :-). Is there a workaround?
Regards
Eduardo Rolon
Known bugs for both 24 and 25:
Read here:
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
mehmetlashari
I updated my Archicad 25 to the latest version where the bug is fixed, and its working fine now and quiting without any bug repoert, thank you.
Shamim
Hello there,
I have the same problem with a Macbook Pro M1 Pro, macOS 12.1 with Archicad 25.
Regards
The current "hotfix", Update 5010 fixes this issue. Please check for updates to see if it is available for your language version.
AC27 US/INT -> AC08
another Moderator
