We have been getting this same result when using teamwork fiels in our office. When opening a teamwork file after working on another project you need to open the file twice to make it load the correct complex profiles otherwise the complex profices from one project get used in the second.
So far we have had;
- 150 SHS columns replaced with frameless glass wall panels;
- 280 I beam steel beams replaced with 3m high brick stormwater drains;
- Signage profiles from one project replicated for every column throughout another project;
It was entertaining to start with, but the time required to re-load a project twice when I am working on more then 5 teamwork projects at once is getting to be a pain?
Graphisoft, known bug? Update patch soon?
Matthew Johnson - POWE Architects
AC4.5 --> AC29 & Revit 2016 --> 2026
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit + Quest3
I'd rather be sailing.
