Thanks, that's the step I missed, if the layers are hidden it indeed gives me that dialog. I have done some more tests between the versions (21to22, 21to21, 22to22), and it seems to be working absolutely consistently for me:
- When the pasted element is supposed to be on a layer that is hidden, then you get this dialog, and the element will be placed where you choose (eg. the ARCHICAD Layer).
- When a pasted element is on a layer that doesn't exist in the file, then it will be created as a new layer no matter what (you don't get a dialog at all). If you get a dialog because of other elements, these elements will still create their own layers.
Is it possible that in your 21 file you used different layers than in the 22 layer, so you don't get a dialog, because all the layers are new?
I am working with the
40xx preview update at the moment. can you try to install that and see if it helps?
Regards,
	Daniel Alexander Kovacs
GRAPHISOFT
